Xerox 4110 Heat roller Kit part numbers
  • ZeusGT
    • 271
    Hey guys,
    I am working on a Xerox 4110 that has a fuser drive gear that is broken in two pieces. I know that I can purchase the heat roller without any issues, but what I'm not sure of is the bearings and gears are included and installed on the heat roller with the "kit" Xerox is selling. I know that the pressure roller includes the bearings and shaft assembly.
    Does anyone happen to know if the Xerox 4110 heat roller kit includes the heat roller drive gears and bearings? If not, can someone please let me know what the part numbers are for the heat roller gears?
    Thank you so much for your help guys.
    CompTia A+ Certified
    CompTia Net+ Certified
    CompTia Server+ Certified
    CompTia Project+ Certified
    OP Scanshare Certified
  • Flash
    • 378
    Re: Xerox 4110 Heat roller Kit part numbers
    I believe the bearings and gear are included with the heat roller. It has been a while since I have replaced one.
