Wc 7232 error code 089-311
  • Reeves
    • Apr 2012
    • 297
    [Error Code] Wc 7232 error code 089-311
    i have a xerox wc 7232 with the error code 089-311 what could be the problem
  • nikaccc
    Re: Wc 7232 error code 089-311
    Probably your IBT Belt Home Sensor Indicator is dirty, or has peeled a little off (damaged) from the IBT Belt, try remove the fuser, and with your hand turn the belt, so you can see the sensor indicator, it is on the belt edge closest to the front of the machine.
