Xerox WorkCentre 7228/7235/7245 HFSI counters chain links
  • Roberto_Blanco
    • Mar 2010
    • 12
    Hello, Can anyone help me with the chain links of HFSI counters for Xerox Workcentre 7235, please ?! Best regards, Roberto
  • xeroxsharp
    • Nov 2008
    • 270
    Re: Xerox WorkCentre 7228/7235/7245 HFSI counters chain links
    Reports MenuTo access the menu of printable reports:1.Enter the CE mode ( Entering and exiting CE mode).2.Press the Machine Status button on the Control Panel. 3.The Machine Status screen appears.4.Select the Billing Meter/Print Report tab. 5.Select Print Report/List.6.Select CE. The following report selections will be displayed:-Debug Log Reporto -HFSI Counter Reporto Jam Counter Reporto -Shutdown History Reporto -Failure Counter Report7.Select the required report and press Start. 8.The report will be printed. 1.Enter UI Diagnostic mode ( Accessing UI Diagnostics). 2.Select Adjustment/Others. 3.Select Initialize HFSI Counter. 4.Enter the Chain-Link No. for HFSI Counter (6 digits), using the keypad on the Control Panel (see Detailed Maintenance Activities for a listing of HFSI items and counter numbers). 5.Select Reset Current Value. HFSI COUNTERS955-806 Document Feed954-801 IBT Belt Assembly 954-802 2nd BTR Unit 954-803 Transfer Belt Cleaner Assy 954-804 Fuser 954-806 Tray 1 Feed counter 954-807 Tray 5 Feed counter 954-808 Tray 2 Feed counter 954-809 Tray 3 Feed counter 954-810 Tray 4 Feed counter 954-811 Black Developer Housing 954-812 Cyan Developer Housing 954-813 Magenta Developer Housing 954-814 Yellow Developer Housing
    • Roberto_Blanco
      • Mar 2010
      • 12
      Thank you very much for the precious info ! Hope I don`t ask too much, but do you know the life cycle of the developer on these machines ?! The reason for which I ask this, is because I have a quality image problem and I don`t have any service manual for this type of copy machine. Best regards and thank you again, Roberto
      • xeroxsharp
        • Nov 2008
        • 270
        No specific life time,you need to replace developer/s,when your copy quality is poor.BR
        • Roberto_Blanco
          • Mar 2010
          • 12
          Ok. Maybe this is my problem. Thank you again ! Have a nice weekend.
