Wc pro 245 reset "1111"
  • ftrinc
    • Aug 2025
    Hello, i had at 22 old kid working for me and changed the "1111" to something. Is there a way i can reset the password and/or the system. Ask the the kids is out as he is locked up for dui. any help or backdoors?
  • seansbar
    • Dec 2010
    • 198
    Re: Wc pro 245 reset "1111"
    Sorry, nothing other than reloading the software via AltBoot will get that password back. If you don't have a PWS, go visit the kid in jail!
    • ftrinc
      Can we download AltBoot or get it. I tryed to see him. Its was not very good
      • seansbar
        • Dec 2010
        • 198
        Do you have a PWS?
        • ftrinc
          Pws? I just started doing this about 1 year ago. This is First time i never had or knew the password
          • seansbar
            • Dec 2010
            • 198
            I'm guessing you don't have a PWS. It is Xerox proprietary software on a laptop. It is needed to do many service items on Xerox copiers. Unfortunatly it also requires an active GSN account to use.
            Therefore, I cannot help you AltBoot your machine. At this point your best bet is call a Xerox authorized tech, or start guessing passwords.
            Good Luck
            • ftrinc
              I'm guessing you don't have a PWS. It is Xerox proprietary software on a laptop. It is needed to do many service items on Xerox copiers. Unfortunatly it also requires an active GSN account to use.Therefore, I cannot help you AltBoot your machine. At this point your best bet is call a Xerox authorized tech, or start guessing passwords.Good Luck
              Can i just replace board in it?
              • seansbar
                • Dec 2010
                • 198
                Nope
                • adriansto
                  • 2388
                  Go to service menu from UI and in" other diagnose" mode and you can reset back admin passwd to 1111.
                  Dont need pws or altboot to do that !
                  You need altboot for other things. Email at stoadis@gmail.com if you need altboot for this machine
                  • seansbar
                    • Dec 2010
                    • 198
                    No way, guess it is so:
                    1. Enter diagnostics, GP 1.
                    2. Select Diagnostic Routines, select Other Routines, select 001 Reset Auditron Master PIN.
                    3. Select Reset Auditron Master PIN.
                    4. Select confirm or cancel.
                    • adriansto
                      • 2388
                      And the final result is ?
                      • efe311
                        • Oct 2008
                        • 114
                        Yes that is wright
                        1- press # & key
                        2- entre pass word that is 1964
                        3- continue ur steps
                        • adriansto
                          • 2388
                          Originally posted by efe311
                          Yes that is wright
                          1- press # & key
                          1964 is your birthday year ?
                          • xeroxsharp
                            • Nov 2008
                            • 270
                            password is 1934 not 1964.
                            • nazmi_exa
                              • Nov 2009
                              • 24
                              GP 3 Resetting the Administrator Password
                              Purpose
                              The purpose of this procedure is to allow the CSE to recover the Administrator Password in situations
                              where the customer has changed the password from the default value, and subsequently
                              lost or forgotten the password.
                              Procedure
                              1. Enter UI Diagnostic Mode.
                              2. Press the Log In/Out button on the Control Panel
                              3. Select System Settings.
                              4. Select Common Settings.
                              5. Select Diagnostics.
                              6. Select NVM Read/Write.
                              7. Enter location 700-171 and press Confirm/Change. This is the current password. You
                              can provide this number to the customer, or set the location to the default value (11111)
                              and allow the customer to enter a new number from Tools mode.
