4110 error 91-914
  • bojans
    • 1313
    4110 error 91-914
    Hi,
    After replacing drum in 4110 constantly getting error 91-914 after 50-100 copies. Consumable not properly seated.
    It also had error 61-320 but after cleaning and adjusting drum detect switch it has gone.
    My friend who has one 4112 machine told me that he resolved this problem by changing IOT NVM pwb. Wouldn't like to order this pwb and have the same error.
    Any suggestions would be appreciated.
  • Milo Wilson
    • 502
    Re: 4110 error 91-914
    Ther is a front sensor on the outboard side where the drum slides in that can give this fault
    • bojans
      • 1313
      Thank you Milo,
      That sensor is in place, and I believe that it's working.
      What you suggest, to change it?
      • XDE-774
        • Sep 2012
        • 12
        this is extract from FIP at PWS
        hope this can solve your problem
        091-914 Drum CRUM Communication Fail
        BSD on:CH9.2
        Description
        A communication failure with Drum CRUM
        Procedure
        Turn OFF then ON.
        091-914 remains displayed.
        Yes No
        | It is highly likely that the MCU PWB made a faulty detection due to some external noise or internal discharge-related noise. Check if there are any noise sources around the machine and if any abnormal discharge has occurred.
        Turn off the power. Disconnect and reconnect the following connectors:
        J406 on the MCU PWB
        P/J171 on the Drum CRUM PWB
        If the above action does not resolve the problem, replace the following in order:
        Drum Cartridge
        Drum CRUM PWB (PL 11.2)
        MCU PWB (PL 2.1)
        • zagrex
          • Dec 2011
          • 63
          BSD On
          CH9.2
          Description
          Procedure
          091-914 remains displayed. Yes No Unanswered
          • P/J406 on the MCU PWB
          • P/J171 on the Drum CRUM PWB
          • Drum Cartridge ( PL 11.3)
          • Drum CRUM PWB ( PL 11.2)
          • MCU PWB ( PL 2.1)
          Originally posted by bojans
          Hi,
          • knightfall
            • Jul 2006
            • 633
            try popping the old drum back in even at 0% there is still a few copies left on the drum, if code goes away then bad drum if now then crum pwb and mcu.
            good luck
            Get your facts first, and then you can distort them as much as you please.
            • bojans
              • 1313
              Thank you.
              I have tried with old drum first, but same thing.
              • Tropix
                • Jul 2011
                • 45
                Thank you.
                Today i have same problem do you solve it ?
                • zagrex
                  • Dec 2011
                  • 63
                  Content URL: "pws://busrec/EKA-4110/XC0522511459907169163161380829970227.dat"
                  SourceName: 4110F, 4112F, D110F Tech Eureka
                  Applies to: 4110 Distribution: Xerox
                  Fault Codes: 091-912, 091-914, 091-915, 091-921, 091-916 Chains: 09
                  Problem:
                  The Customer complains that the machine keeps asking them to reseat the drum cartridge, and if the cover plate is on the drum it makes the machine inoperative. Fault History records 091-xxx fault codes. Reseating the Drum module gets it running, but it happens again. Sometime a new Drum cartridge works from new to end of life but others exhibit this problem.
                  To test if this is your problem pull on the module without releasing the latch. If it pulls out easily, you have a problem.
                  A properly biased latch should hold it even when you pull on it (within reason).
                  Cause:
                  The Xerographic Latch doesn't have enough spring to hold it in place.The image below shows a good one where the sliding pin is sitting at the top of the cutout. A bad one won't spring back to the top of the sliding cutout. (Took the picture after I fixed it).
                  During a run, the module would get pushed out of the machine just enough to give a bad reading. A good push on the module would clear the fault temporarily.
                  I've used 2 methods: The 1st was to warm up the plastic that acts as the spring to bias it more in a way as to provide more spring in the latch. To do this, remove the latch. It can be removed without much effort.
                  <------Spring
                  The 2nd was to add some material to the area where the latch "spring" pushes. In the photo, I used a pad from another machine and covered it with scotch tape. It increased the bias of the latch keeping it in place. I've seen this problem on 3 out of 6 of the modules my customer has received.
                  <-------------added spacer & tape in here (latch is removed)
                  860493.Reseat Drum or Drum Not In Position messages 2009-08-05 00:46:08
