Light bar/Uneven color
  • ManassasRalph
    • Oct 2007
    • 18
    Xerox Docucolor 252 has developed a light bar/uneven color across the lead edge of the sheet. The light color shows on each color when individual colors are printed.
    Any help is appreciated.
  • maich4s
    • Mar 2009
    • 86
    Re: Light bar/Uneven color
    kindly attach another clear image,with 50%solid
    • azehnali
      • Nov 2009
      • 679
      looks like you need to clean the cyan ros
      • kalindd
        • Jun 2008
        • 192
        With all due respect to azehnali. If it is ROS then it should be the magenta ROS, because from this sample it looks like magenta is missing in those blue letters.
        Which side of the scan is lead and which is rear edge? Please draw that on the scan.
        Check your 2nd transfer current, may be lower it a little bit.
