Xerox DC3535 problem [ERROR 009-349]
  • Proximus
    • Jan 2012
    • 7
    Hello,
    I bought used copier a week ago. We tested it and everything was ok, printing was great. Then i transported mashine in mini van about 600km.
    Now when mashine starts i got grayed copy/print function. I found serial cable, and found working Xerox PSW 2.7..
    Diagnostics give me only one error: 009-349 | 1st BTR retract fault
    what can be problem here? on service manual says it is maybe dirt sensor?
  • bojans
    • 1313
    Re: Xerox DC3535 problem [ERROR 009-349]
    Pozdrav Martine,
    Ajde probajte da izvadite sve bubnjeve i ponovo ih vratite u masinu ali dobro pazite da upadnu u leziste kako treba. Zatim upalite masinu.
    Pozz Bojan
    • Proximus
      • Jan 2012
      • 7
      Bojane i u kopire se razumijes
      nasao sam na netu prije par dana da to moze biti uzrok, probao 4-5 puta vadio vracao, nije do toga...
      Danas sam skupio hrabrosti da skinem "IBT Belt", radio sve po servisnom upustvu, dosao do "1st BTR retract" senzora izduvao ga zrakom, sastavio sve vratio kako pise, al opet isti error...
      sto je najgore ne znam dal ima iko u CG da servisira Xeroxe :/
