Xerox Workcenter 7328 7335 7345 7346 error 004-346, needs reset
  • ruthndul
    • Sep 2012
    • 12
    Got this machine in error 004-346
    I realized that it's the belt,
    when I pull out the tray, the belt was torn.
    Ordered the belt, take it to a service center and have the belt replaced there.
    I installed the tray back, but the error still shows.
    Searched on google, it needs reset.
    Does anybody can share, how do I fix this error ?
    thanks.
  • ruthndul
    • Sep 2012
    • 12
    • johnner66
      • Mar 2009
      • 265
      Re: Xerox Workcenter 7328 7335 7345 7346 error 004-346, needs reset
      use the code 741-056 reset it to 0 hope it work
      • ruthndul
        • Sep 2012
        • 12
        How do I access that menu ?That menu is not accessible
        • adriansto
          • 2392
          Tried press 0 for 5 secs, hold, and press start button together, type in 6789
          Press the Machine Status button on the control panel.
          Select the Tools tab on the UI screen.
          Select System Settings.
          In the Group column, select Common Service Setting
          In the Features column, scroll down to Maintenance / Diagnostics
          or use Software Download Tool an use Nvm Tool
          • ruthndul
            • Sep 2012
            • 12
            that menu is not accessible.
            • Colobosto
              • Oct 2013
              • 5
              Press the Machine Status button on the control panel. Or else the 4rth (last to the bottom) button from the right of the touch screen
              after that, if you switch the menu in english, it is as our friend mentioned...
