xerox wc 73xx series, some menus are inacessible
  • ruthndul
    • Sep 2012
    • 12
    Got an error 004-346 xerox wc7335
    It's the IBT belt
    Ordered the belt
    Replaced it on xerox authorised service centre
    Reinstall it
    The error message remains the same
    I know it needs reset
    I pressed 0 for 5 seconds, + start
    Typed in 6789, enter
    Go to maintenance and so on
    But when I click on the NVM button to reset the error
    These buttons aren't accessible
    Do anybody can help me ?
    I'm not a technician.
    Just a home user
  • adriansto
    • 2392
    Re: xerox wc 73xx series, some menus are inacessible
    Do you read my post in this topic :
    http://www.copytechnet.com/forums/xe...eds-reset.html
    It works or not ?
    Why you dont place a call to an xerox tech ?
    • ruthndul
      • Sep 2012
      • 12
      no, it doesn't work.
      it's not in service contract with xerox.....
      they charge $190 / 30 mins !
      initialise NVM works
      but after that,
      all section is not accessible.......
      • adriansto
        • 2392
        What software version do you have on machine ?
        Can you post here configuration report ?
        • ruthndul
          • Sep 2012
          • 12
          It's 1.221.5
          I couldn't access configuration menu.....
          • adriansto
            • 2392
            Try this:
            simultaneously press and hold the 4, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (progress bar) appears.
            and after that try to access again diagnostic menu.
            • ruthndul
              • Sep 2012
              • 12
              I tried your advise this morning
              Unfortunately, it doesn't work either
              It's like the machine is half locked....
              • adriansto
                • 2392
                Then you may try to use nvm access tool or try to reload software
                • ruthndul
                  • Sep 2012
                  • 12
                  How do I do that ?
                  I don't have the software.....
                  Can u help me pls ?
                  • adriansto
                    • 2392
                    Originally posted by ruthndul
                    How do I do that ?
                    Can u help me pls ?
                    Send mail at stoadis@gmail.com
                    • jd3434
                      Dear,
                      Go to nvm loction and reset the error code. nvm chain link is 741-056 reset it to 0[zero].
