Blue Lines on output
  • Alan Aya
    Got this call from a customer this morning, the print out & copy have a lots of blue line on one side of the paper. Attached are some sample print taken back from customer's place, Can someone give me some clue to solve this problem?Blue Lines 2.pdfBlue Lines 2.pdf
  • adriansto
    • 2383
    Re: Blue Lines on output
    Excellent question !
    May be I can respond to you if you say what is the lead edge of print and of course about what machine we talking.
    • Masterchief
      • Apr 2011
      • 280
      Hello
      I am not to common with Xerox machines, I have looked at all 3 pics. I would start by doing a black and white print obviously, and if thats all fine then thats the BK PCU and DEV out.
      Next try all colours Cyan, Yellow Magenta prints... This will narrow it down but judging by those copies i would say
      The cyan Drum unit is not working effectively and causing lines on copies either the cleaning blade is shot or it aint conducting correctly
      The Magenta unit looks to be on its way out as the per te image so clean or replace this unit.
      How is the Transfer belt and cleaning unit are they working fine???
      sigpic
      • Alan Aya
        OK, this is DCC450 and if you are looking at the 2nd sample ( the Spiderman ) the finger of the spiderman is pointing towards the front of the machine ( the Control Panel ), which means those blue lines are in front of the machine.
        • bojans
          • 1313
          If DCC450 is the same machine as Xerox DC3535 you have problem with cables from rip to machine.
          Power off machine and reconnect all cables.
          • Alan Aya
            Do you mean the cable connecting the scanner reader unit to the main printer?
            • adriansto
              • 2383
              Yes the two cables. Power off machine, remove cables and power on. In this mode machine start only as copier. Them make a colour copie and see what is.
              • AussieXeroid
                • Sep 2012
                • 5
                If other colours are fine, Cyan (R2) drum possibly faulty, You can diagnose by swapping drum to different position and check if symptoms change. Also you can see in number 1 pdf slight diagonal banding, this means your developer has diminished and will need to be replaced. Is also possible that something foreign in Cyan developer could cause the problem (which if you eliminate the drum will be most likely)
                And the DCC450 even though having the same print engine as DC3535 is very different. The 3535 has a RIP. So the cables to scanner are most likely of little relevance.
                • bojans
                  • 1313
                  Thanks for the info about machine Robert
                  So, yes, forget about cables. There are no cables!
                  • anulu
                    • Sep 2012
                    • 20
                    Could be the laser (ROS) cabling, Or the Drum Charge Roll Contact inside the machine?
