x12 fiery help..
+ More Options
Posts
  • photophil from NH
    x12 fiery help..
    We have a x12 rip that has been acting odd lately & now its just plain bad... solid colors & graphic seem fine but gradations look posterized- almost like were not raserizing at a high enough bit rate. Im unsure if this is a function of the rip board or sofware- calibration output does not exhibit this problem. - NO problem off the glass
    Attached file ( while taken with an iPhone ) shows the problem
    any suggestions?
    thank you !!!
  • photophil from NH
    Re: x12 fiery help..
    so I did a restore from backup, did the setup & calibrate ...
    same results
    the fiery comparison page looked PERFECT... but not my files.
    So the printers is fine and the rip can send good files...
    gulp...
