Xerox WorkCentre 7235 010-398 error
  • Roberto_Blanco
    • Mar 2010
    • 12
    [Error Code] Xerox WorkCentre 7235 010-398 error
    Hello,
    I have a Xerox WorkCentre 7235 with a 010-398 error. Changed the Fuser, but the problem persists. Sometimes the machine reboots itself after the error and sometimes it just saying the "An error has occured, please shut down the machine". The machine have 1.055.000 prints and it started to give this error after i changed the black developer tank, might this have any connection ? Changed the tank, reset the counter and worked fine for a day or so. After I restart the machine it can go 1000 pages or 10 until it gives the error again. I don`t have the service manual and on Xerox website it says to change the Fuser, wich I did. Does anyone have other ideas ?
    Thank you,
    Roberto
  • johnner66
    • Mar 2009
    • 265
    Re: Xerox WorkCentre 7235 010-398 error
    try replace the fuser fan good luck ????????????
    • Roberto_Blanco
      • Mar 2010
      • 12
      Even if it is working ? I checked it and it spins and with the machine off I can spin it with the fingers very easy.
      • bojans
        • 1313
        Those fans have two speeds. It spins on first "gear" but when if have to go faster it fails.
        • Roberto_Blanco
          • Mar 2010
          • 12
          Thank you for explaining that to me. I just ordered the fan. I will post an update after changing. Thank you again guys.
          • bojans
            • 1313
            I had thread how to fix it but couldn't find it.
            But you'll see in picture. Tear off some plastic just to see SMD resistor and resold it.
            • Roberto_Blanco
              • Mar 2010
              • 12
              [ATTACH=CONFIG]17453[/ATTACH]
              Will do it, thank you very much mate. Cheers !
              • bojans
                • 1313
                You're welcome
