activated copy of 510dp wide format
  • walidcharifi
    • Feb 2011
    • 379
    hello
    I xerox 510dp
    configuration page
    activation of copy: standard
    activated copy: disables
    the network license num: present
    num to network activ: disables
    how to enable copy and num to network
  • technogeek2009
    • Mar 2011
    • 167
    Re: activated copy of 510dp wide format
    Not entirely sure about what your problem is. Are you unable to make copies? Could you explain what is not working on the system?
    If the scanner is not being recognized by the controller, you may not have DDS Enable turned on. If the machine is connected to your network, input the IP address of the system into a browser window on a workstation connected to the network. This will pull up the printer web interface. Look under Configuration, and Printer Set-up. There will be a check box labeled DDS Enabled. Check the box, and then press the button Update Printer. Then reboot the system, and try to copy.
    As a note about the scanner, if you don't boot the system up in the proper order, the scanner may not be recognized by the controller. When booting up the system, first turn on the scanner. Wait until the display in the rear of the scanner indicates the letter "P" then turn on the printer and controller.
