I have a 510 wide format plotter with an error code of LL-81. Can anyone help with this?
510 Wide Format Plotter
Re: 510 Wide Format Plotter
Attached Files -
The LL-81 code is most often caused by a bad AC Module. Check the resistance across the fuser rods and thermistors first. You will also want to closely inspect the blue connector that interconnects the fuser drawer and printer. Pay particular attention to the connectors associated with the thick wires. These are the leads that pass power for the fuser rods. Over time, it is common to find one or more of these pins pitted or deformed. When this happens, it causes excessive current to be drawn through the AC Module, and in turn cause the drivers in the unit to blow. So you could conceivably replace the AC Module only to have it fail shortly there after, due to failed contacts in the blue connector.
I can help you with parts to repair this problem if you need them. cbyrne@goevergreen.netComment
DAHstra
Could someone please post the text of the source of that image into this thread? Imageshack is blocked at my work. :-(
Thanks!Comment
asifmeeran
Looking for a fix .I have an error on my Xerox 510 plotter 'LL-83" can any one assist what cause the reason and the fix for this.Comment
Hello everybody! I've got LL-81 error not long ago on 510. In my case problem was in AC-module.
Found on one of the boards there - Bridge Rectifier Single Phase 600V 35A - and resolder it. And that helps me a lot. 2016-09-07 12-34-08.jpg
GBPC3506W, if someone need it.
Hope it would be usefeul. Good luck guys!Sent from Ericsson DBH 1001.Comment
Found on one of the boards there - Bridge Rectifier Single Phase 600V 35A - and resolder it. And that helps me a lot. [ATTACH=CONFIG]34125[/ATTACH]
I have the same problem ll-81 I replace GBPC3506W
but no result.
help meComment
