I have a Xerox 5687 that doesn't communicate with its Network controller, faults sequence is 03-340, 03-367, 03-544. Changed the firewire cable and card, no result. The defect was after changing the IP configuration from the user interface and it's likely the copier can't communicate with its Network controller. Network Controller can be pinged from any workstation and shows the new IP address given. What else can be done? Is there any NVM in the copier to be changed in order to give it the new IP config that was put for the Net Controller? Any help will be appreciated. Thanks in advance.
Anastas
Anastas
