This week the IBT Belt was ripped two times. What could be the cause of that problem. Anybody faced the same problem?
ripped IBT Belt on c2636
Re: ripped IBT Belt on c2636
Besides the obvious setup errors, I've had a bent Blanking lamp support rail pinching the belt causing breakage. Since the customer changes black most often it's the first area to suspect customer errorsigpicComment
Hello, bojans.
Yes, i did this procedure. After replacing the belt the printer printed about 500 sheets and then ibt belt ripped again.
Ibt belt costs about 600$ and i must be a 100% sure before replace new one again.Last edited by Tinochka; 10-22-2012, 08:40 PM.Comment
thanksComment
Today I did Belt Edge Learn procedure. ( I made pictures, possible it helps.) The belt seems to be too left to compare A and B (attached picture )Attached FilesComment
If you suspect the belt is moving too far to one side check the Belt steering motor is turning as it operates.sigpicComment
Motor operates fine. I shift belt to the right before starting belt edge learn procedure. The belt moved to the left and kept this position. And I saw steering motor operated a bit CCW and then CW a few times. I understand it keeps belt in that position. I think if the Belt edge learn is succesful, the motor and belt edge sensor are fine?Comment
If its maintaining a good position. I would watch it operate for a while. Check registration of colors. Watch for shifting, smearing, or noise. Anything indicating something is interfering. If you have another IBT assy swap it and see if it acts the same way. Isolate the machine or the assy.sigpicComment
Didn't see your post. Yeah they can go bad. One spring putting too much or not enough pressure on one side. A bearing worn. Not the easiest to trouble shoot.sigpicComment
Anyway thank you.Comment
