scanner for 510 wide format
  • walidcharifi
    • Feb 2011
    • 377
    hi
    my scanner Synergix wide format
    when I put the paper to make a copy * ll-47 *
    and * width detection failed pleas entre width of centre-registred document *
    i entre width 914mm
    - the whole page is black
  • technogeek2009
    • Mar 2011
    • 167
    Re: scanner for 510 wide format
    Looks like you are going to need a manual for the scanner, and do some diagnostic work. Below is what the manual recommends for the LL-47 error code. However, black image is yet another problem, separate from the LL-47 error. I would try re-seating all the connectors going to the main board, as well as the image processing board atop the main board.
    LL - 47
    Gain calibration failure on Channel 1. (Dark streaks).
    NOTE:
    LL-47 displayed only momentarily on Scanner Control Panel.
    Examine the Calibration Target Strip, the SelfFoc Lens, and the Platen Glass for dirt or contamination; clean if required. Use the Calibration Motor test in Scanner Diagnostics to rotate the Calibration Extrusion and gain access to the target strip.
    Replace the Lamp [REP 6.4 Exposure Lamp], particularly if the lamp has discoloration at the ends.
    Go to the Scanner Diagnostics and do the Full System Test. Troubleshoot any failures. Do the Scan Bar Calibration Test. Troubleshoot any failures.
    If the problem still exists,
    replace the Scanner Main PWB [REP 3.1 Main PWB]. If the problem still exists, replace the Image Module [REP 9.2 Image Module].
    BSD 6.2 Image Capture
    PL 1.4 Electrical Module
    PL 1.3A Image Module and Document Feed Rollers (Part 1 of 2)
    • walidcharifi
      • Feb 2011
      • 377
      LL - 47
      NOTE:
      fine
      • epsylon
        • May 2014
        • 3
        sorry anybody have the part number of the exposure lamp
        • technogeek2009
          • Mar 2011
          • 167
          We stock this part 122E02640 $258 plus shipping.
