Need help on DocuColor 8000
  • copy.center88
    Hi, I am new to color machines, and now there is problem in my DC8000.
    When printing solid color, the output is not equal from right to left. In portrait position, at the right side(1/3 of the paper), it is gradually more darker than other.
    But the most problem is when printing in solid grey more than 50%, the output color in the right side is tend to more blue-green than other.
    I've change the corotron and drum unit, but still the same
    What is wrong with the DC8000? Does it need any adjustment? What kind?
  • azehnali
    • Nov 2009
    • 679
    Re: Need help on DocuColor 8000
    you need to do the color balance and for that you need a laptop
    • copy.center88
      @azehnali: thank you for the answer, but how to do the color balance? does it need special software? Thanks
      • azehnali
        • Nov 2009
        • 679
        You should call a trained tech with a xerox pws software and one that knows what they are doing
        • XeroxTechBrazil
          • Aug 2008
          • 199
          Like its predecessors, the 20xx, 5252, 6060, the 7000/8000 is an easy machine to service. You need the PWS laptop with the EDOC, and all-important SNAPs (the service bulletins and tech tips). There IS a learning curve, but there are extensive training helps available.
          You will need the PWS to run the diagnostic routines (Max Setup) that will trouble shoot and fix your balance problem.
          If you need a PWS please email me at
          JorgeXcalak@live.com
          My current offering is a factory refurbed Lenovo T61 Widescreen with a new 500 GB HD. It has over 100 current EDOCs, with corresponding SNAPs, and diagnostic tools where appropriate.
          Price is $1K plus $55 2 Day Fed Ex in the US. I ship internationally. This is a turnkey product that you can immediately begin to use.
