the machine will print/copy a job just fine then indicate to open rear cutter door. after opening and closing the rear cutter door to reset, the machine will reprint the job and say open rear cutter door. repeat process and it will reprint in an endless loop until you cancel the job. sometimes it will not cut the sheet and the print job will hang out of the machine and you will have to manually cut and reload the roll and it will reprint.
i admit i am not very familiar with this machine. any and all ideas appreciated. oh, this all started after a storm and the power had flickered several times
