Xerox Phaser Model 8560 Error Code
+ More Options
Posts
  • Tech2002
    • Aug 2008
    • 334
    [Error Code] Xerox Phaser Model 8560 Error Code
    I've got an error code - 09,037,45:38775.
    Supposed to be an exit area code. Could not find any debris in exit area. Cleaned 2-sensors. Still no luck.
    Anyone have any suggestions?
    Appreciated.
    Thank you.
  • JustManuals
    • Jan 2006
    • 9838
    Re: Xerox Phaser Model 8560 Error Code
    http://www.justmanuals.com/index.php?main_page=index&cPath=388_395
    Paul@justmanuals.com
    • CopierTechofOmens
      Agitating Artificer
      • 268
      That error usually happens from using aftermarket inks. Go into diagnostics and clear the ISC faults
      sigpic
      • KJEpps
        • Jun 2012
        • 63
        Appreciated.
        Thank you.
        That error indicates the there is a stuck Yellow ink stick in the ink loader. It can be from 3rd party ink or any broken/cracked ink stick in that slot. I've also seen it happen for no apparent reason at all. First thing to do, as CopierTechofOmens suggested, is "Clear ISC Fault" from the Internal Diagnostics Function Menu. BTW, ISC stands for Ink Stick Count.
        • Tech2002
          • Aug 2008
          • 334
          Thank you for the input. I really haven't seen this before with the Ink Sticks, but, stuff happens - especailly with my client.
          Thanks again, anything I can learn is appreciated.
          Be well.
