XEROX workcentre M-118
  • ATSBMCO
    Technical
    • Oct 2007
    • 70
    We have a customer with this model, I'm not that familiar with it, and the fault shows system error EP-0003. Does any body know what it means and how to re-set. Thanks
  • JustManuals
    • Jan 2006
    • 9838
    EP0003: EP-A line error occurred
    HtH
    Paul@justmanuals.com
    • ATSBMCO
      Technical
      • Oct 2007
      • 70
      Thank you for your information, is there a reset for the error?
      • JustManuals
        • Jan 2006
        • 9838
        Dunno, I didn't read the entire manual. I looked up the code that's all.
        • blackhat
          Hi,
          first Check the connection of each MFC PWB and EXT PWB connector. Be sure that all connection are connected proprely. Power on, if the same problem occur, you should replace the MFC PWB P# 960K05230
          Good luck for u
