DC250 transfer belt reset URGENT
  • afropro
    • May 2012
    • 61
    Hi there guys, I have removed the mechanism where transfer belt is, and i have rotated the transfer belt i have done some cleaning, but now i got the error code that i need to re position or to center the transfer belt and i don't have a clue how to find the spot where it should be centered please can someone help me how to reset the transfer belt and start working again. thank you.
  • amadeusmbi
    • 51
    Re: DC250 transfer belt reset URGENT
    you put upside down (rotate, search patch and home position sensor) or not centered (manually center and then "edge belt learning" procedure).
    What error you have?
    "Opportunity is missed by most people because it is dressed in overalls and looks like work. "
    • afropro
      • May 2012
      • 61
      I had this error 042-326, but doing a little exploring around the internet and on the manual, i have managed to find the solution, it was simple just position the reflective mark in the up side of the mechanism and it worked, and i cleaned the reflective mark not to forget, it works good, hope it doesn't get again the error. Anyway thank you very much.
      • slybot
        • Sep 2010
        • 165
        you need to clarify; a dc250 (black and white) does'nt have a transfer belt. A DCC250 (color machine) does. not being nasty here; but the more and correct info the better
        • afropro
          • May 2012
          • 61
          Well DC250 means docucolor250 at least that is writen in my machine, i have never heard of dc250 black and white printer. anyway i have fixed the problem thanks.
          • bojans
            • 1313
            HI slybot,
            At this part of the world dc means DocuColor.
            • slybot
              • Sep 2010
              • 165
              Originally posted by bojans
              HI slybot,
              you have to love the non generic side of the planet don't you?? with dc in the bottom of the planet means docucentre. dcc means docucentre colour. gotta love it NOT!
              • slybot
                • Sep 2010
                • 165
                wasn't ragging on you; sorry if you thought i was. not my intention. Glad you fixed the issue. may be known as a dc 2551 or so?
                different parts of the planet and different names of machines
                • afropro
                  • May 2012
                  • 61
                  No dont worry, its ok,
                  • slybot
                    • Sep 2010
                    • 165
                    merry xmas and all the best for the new year. start my new job on the 2nd of Jan. will see how that goes
