You can tell if its a problem with your magenta drum pretty easy. Swap the magenta drum with the yellow drum. If your magenta line becomes a yellow line you know the problem is with the drum unit.
A void line of any color most often can be caused by a defective developer unit or dirty laser glass but won't cause a printed line.
Most often a printed line of 1 color is caused by a worn drum unit.
