Xerox Work Centre Pro C3545
  • flickerfree
    [Misc] Xerox Work Centre Pro C3545
    I have (previously) once managed to get into the "firmware reset" on the xerox 3545 which allows the setting on NVRAM and options, which are coded as a set of rather cryptic number settings, and allow changing a wide variety of options (including for instance, the counters) on a C3545.
    However, sadly, we've just got a new unit, and via hook nor crook have I managed to switch it into debug mode.
    Press * and # and Access displays the language choice screen.
    Press and hold 0 then Access does not seem to place it into debug mode.
    In fact, most frustrating it is too.
    Does anyone happen to have some suggestions as to the "magic keystroke" to return this fine unit into installlation mode, where I can go and reset these fine settings.
    I know that it doesn't have the full "error diagnostics" via the touch screen, but it does have some settings (beyond the usual user ones, which are all set to "Call Xerox".
    We purchased the unit at Auction and I'm getting rather peeved.
    Best regards,
    Frustrated C3545 owner
    System Software Version: 0.1.4.520
    Net Controller Software Version: 03.04.520.03
    UI Software Version: 0.1.4.520
    IOT Software Version: 9.0.3
    Finisher Software Version:
    Scanner Software Version: 1.4.0
    Immediate Image Overwrite Enabled: disabled
    Startup Config Report Enabled: enabled
    Banner Sheets
    Banner Sheets Enabled: disabled
    Document Defaults
    Type: System Default
    Color: undefined
    Copies: 1
    Sides: 1
    Plex: simplex
    Output Tray: top tray
  • adriansto
    • 2386
    Re: Xerox Work Centre Pro C3545
    Not such " miracle "
    • seansbar
      • Dec 2010
      • 198
      The only way I know to reset counter will force the machine into manufacturing mode. Then without a PWS, you got a large boat anchor. But since the scanner is separate from the IOT, it is a poor boat anchor.
      Why are people so quick to reset the counters? It like resetting the odometer on a Pinto. It ain't going to be magically new, and either way, it is worthless.
      Sorry, man, you bought an old copier. Resetting the counters ain't gonna make it new again. Should have done your research before bidding.
      As for your "Call Xerox" settings, not sure what that meant but, your best bet is to call a trained tech.
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
