Docucolor 240 Error code 093-320
  • Taz8it
    [Error Code] Docucolor 240 Error code 093-320
    Hello,
    I need some help. I have a Docucolor 240 with an error code 093-320 developer motor failure.
    I do not have a service contract with Xerox. I am looking for some help on how I might be able
    to fix this.
    Thank you
  • adriansto
    • 2388
    Re: Docucolor 240 Error code 093-320
    Originally posted by Taz8it
    Hello,
    to fix this.
    Thank you
    It is a good ideea to have a service manual for this machine.
    It is a lot of measurements to do to see if the motor is crash or you have defective electronic board
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • davidj7
        • 1107
        Problem:fault code 093-320 when powered on----------
        Cause:
        Problem with yellow , magenta and cyan developer motor rotation ------
        1- reset following NVM to 0
        762-312 762-313
        762-314
        762-315
        2- Checked 24 Volts on PJ205 and 5 Volts on PJ206 , if it is good replace developer motor ( item 19 PL 1.6 )
        and get a service manual
        a machine is only as good as your tech : source:screwtape ; the scary one
