Xerox 4112 Error 077-313
  • Tropix
    • Jul 2011
    • 45
    [Error Code] Xerox 4112 Error 077-313
    Hello, i have a problem with xerox 4112. When i turn it on there is no error, but when i want to print or copy the paper comes to registration and the mashine stops with error 077-313.
  • CopierTechofOmens
    Agitating Artificer
    • 268
    Re: Xerox 4112 Error 077-313
    Originally posted by Tropix
    Hello, i have a adultery with xerox 4112. When i turn it on there is no error, but when i want to print or copy the paper comes to registration and the mashine stops with error 077-313.
    1. Cause: Multi Sheet Check Sensor Actuator loose due to torsion spring disconnected from the arm. Due to improper removal of paper jam at Registration Roll.
    2. Solution: Remove registration assembly, remove Multi Sheet Feed Sensor reattach the torsion spring on to the arm notch
    sigpic
