Xerox 7665 UI calibration issue
  • copierpro
    • Apr 2007
    • 270
    Have a 7665 trade-in display calibration needs reset - you press an "a" entering admin and get a "j", press "Copy" in "services" and "Network Scanning" opens etc.
    Any tips? Don't have a service PWS laptop can I enter NVM or something through control panel?
  • bojans
    • 1313
    Re: Xerox 7665 UI calibration issue
    There is UI Diagnostic Tests menu. To enter this mode simultaneously press the Phone, #, and * buttons. The menu displays a list of 8 choices. Choice 2:
    "Touch Panel Calibration - Use the Touch Pen for this routine. Start the test and touch the cross hatch locations as they are displayed. This will set the correct points of origin for the display"
    • copierpro
      • Apr 2007
      • 270
      thanks for the info! when we touch the first cross that appears top left nothing happens
      • bojans
        • 1313
        Then you'll have to replace touch screen.
        Or you can try to repair it with hot air. Try to find post here on CTN how to repair touch screen and where to apply hot air.
        • copierpro
          • Apr 2007
          • 270
          Fixed. Reseated UI cable powered up calibrated.
          • bojans
            • 1313
            I'm glad you fixed it.
            Cheers
            • copierpro
              • Apr 2007
              • 270
              Thanks for your help I appreciate it!
              • Enzo
                • Jul 2009
                • 413
                Hi friend. How exactly did you solve it?
