DC 250 Error code 124-341
  • ricardobres
    • 147
    I have a DC250 with error code 124-341. I inicialized de Sys, but the error code persist.....Any idea?
  • adriansto
    • 2387
    Re: DC 250 Error code 124-341
    Try GP4 and after that reset SYS1 using UI diagnostic
    • ricardobres
      • 147
      Thanks. I did it, and I inputed again the serial number on the IOT, SYS1 and SYS2, and now the following message appears on the UI"cosumables were not seated properly or need replace", I replaced all the toners and the message continues, but the error code was clean.
      • adriansto
        • 2387
        NVM corruption,
        What errors you get ?
        Somewhat like 91-9xx and 93-9xx ?
        If that is situation then you need to restore nvm manually from machine nvm sheet or using pws tool
        • ricardobres
          • 147
          Thanks...I I'll try it on monday....
          • ricardobres
            • 147
            Worked...I restored all nvm manually...thank's...
