Copy function "soft switch" What about Scan to PC, Emails and others
  • mooni3
    • Jun 2025
    Hi lovely ppl,
    First time posting here so forgive/notify me if i posted the wrong stuff @ the wrong place.
    So as of the above topic, i recently got into copier tech trade and am learning stuff bit by bit. But there is a problem which came up just last week hope u guys can guide me on what is the best solution.
    Customer A wans to enable auditron but dosen't wan to disable the "Device Access".
    Only way i thought @ that point of time was to go in CE Mode and NVM Read/Write to change the copy chain-command from 1 - 0.
    That totally removed "Copy" from the startup screen unless u log in to the users created in the auditron.
    Customer B wans to remove Email/Copy/Scan to PC.
    This kinda got me stuck as i only noe the chain-command for Copy.
    So if anyone could tell me how to go about solving this problem or someone would be kind enuff to let me noe the chain-command codes for Email/Scan to PC, that will be awesome.
    Model number is DC4C4475. I believe the DC4 variety of copiers should have the same/almost the same command codes for most of the features.(correct me if i am wrong)
    Much appreciated.
    moonie(fellow newbee tech)
  • mooni3
    Re: Copy function "soft switch" What about Scan to PC, Emails and others
    bump for help~
    • copytech200X
      • 264
      For ur case u can customize the screen scan to email,pc just remove it so user cannot seen scan features at all.
      • mooni3
        how do i go about doing it? i am new so the only way i noe to go about that is to use NVM read/write.
        or i might be missing out something completely. =x
