Checked connections, resteated firewire comm and controller boards cleaned out with forced air, reseated boards still get error. Bought new firewire 800 cable form com to controller. Still getting error.
Next step is new ieee1394b Firewire 800 PCI PWB for com that slides out of left-side rear of copier readily available open market. This is correct board to buy, correct?
If that doesn't work will have to try the controller Firewire card. Is that a Xerox proprietary board? I hope not.
We don't have the PWS for this machine is there a reset in CE mode we might try to clear out error? INitialize NVM? Think we need to do that anyhow snce previous user changed the user name admin and/or password "1111" on web interface - will that clear out user stored username and PW?
When we press energy save and start and power up UI gets dark and can't read anything so any help getting into CE mode correctly appreciated and answer as to clearing our previous user's custom username/password.
Thanks in advance
Thanks in advance
