I need a Xerox repair tech who wants to make some cash on the side. Needs to be able to repair the Xerox Workcentre 7655. Good extra money for gifts, vacations, etc. Hush Hush. Located in Wisconsin. contact Theresa at graphicpoint@ntd.net if interested.
4-563.0 System Fault. Notify your System Administrator. What can I do to fix this?
Machine boots up and shows the message ''Please Call System Administrator''. The User Interface current faults shows a fault code 4-563. That fault code is not in Edoc
Hook up the PWS and check the Fault History. In my case fault code 42-326 was the most recent fault. Troubleshooted that most recent fault .Through the UI Diagnostic, reset IOT Finisher nvm 741-105 to 0 and replace parts as needed. The machine had over 300K so I replaced the IBT Belt (PL 7.3 item #14 part #675K18280) and the IBT Cleaner (PL 7.3 item #1 part #42K92754).
