WorkCentre 7545 - fusing unit replaceable by end user ?
+ More Options
Posts
  • jazzfan1980
    • Jul 2025
    [Misc] WorkCentre 7545 - fusing unit replaceable by end user ?
    http://www.xerox.co.uk/office/multifunction-printer/colour-multifunction/workcentre-7545-7556/supl-e...
    except for the fuser module.
    Does anybody know if Xerox does supply the fuser module directly to the end-user or only to the field technicians ? (I know the unit is quite easy to replace).
    Thank you very much in advance for your answer !
    Best regards,
    Lionel
  • Flash
    • 378
    Re: WorkCentre 7545 - fusing unit replaceable by end user ?
    Yes it is customer replaceable. There are 2 thumb screws that hold it in. It takes about 5 seconds to replace.
    • jazzfan1980
      Thank you very much for your answer. I knew the unit is easy to replace, but I was wondering if the fuser was in fact supplied to the end customer. I finally called the Xerox consumables service in Europe. I was told that if the fuser needs to be replaced, a technician is sent out to the customer. The fuser does not appear on the list of consumables the customer can order (even though it is very easy to replace).
      • seansbar
        • Dec 2010
        • 198
        I don't see why not. If you can find a place to purchase a fuser, you can put it in.
        Part number: 220V fuser for a 7545 is 604K62230. I'm from USA and assuming you need a 220 volt fuser due to the .uk in the URL. My edoc does not differentiate any difference from Europe on this part.
