Factoryl Reset Xerox Docucolor 240
  • mrdummy
    • Feb 2013
    • 26
    Yes, it's easy question. But how difficult is it?
    At my work, we have bought used Xerox Docucolor 240 from another business and installed it.
    Problem, it's already configured in old business.
    The machine is working ok, Fiery controller behind is installed.
    Because it has already fixed IP, i must set own 'network' to see the controller. It's indeed visible at own network ip.
    I have already googled for solutions, but there are too much trash information and nothing useful.
    Even simple copy mode is blocked by user id. Password is not known from old business.
    That is why i try ask here for simple answers.
    I want:
    - set machine back to factory setting (thus like from new installed machine)
    - set ip address to dhcp or change another ip
    - and important; delete admin password and make it new with new admin, so i can reconfigure the machine again.
    I have wasted many hours to check the admin access, but it's clear there is no default password for it.
    I hope you can give me simple answer how i can reset the machine and Fiery controller. HDD format is no problem, cleaning history and logs is okay.
    I want use the machine like new start.
    Thank you very much.
  • mrdummy
    • Feb 2013
    • 26
    Re: Factoryl Reset Xerox Docucolor 240
    Found in the dark areas of Google Search some info. Very little, but got it!
    It's Diagnostics Mode setup.
    Found the manual for it, and it works.
    Finally i can change the settings.
    Now checking which printerdriver is useful for Fiery controller...
    • mrdummy
      • Feb 2013
      • 26
      Fiery scan for Xerox Docucolor 240
      Printer driver found. Because there are 2 drivers possible for printer D240/250, i have tested both drivers.
      After some testings, i found out port 9100 is not working good (text-only prints). But printer has more ports, and found out port 9102 is best port. It's used for Print.
      The printmode is in RAW mode.
      The 'Xerox universal driver' is not working great, but D240/250 driver for built-in fiery is working great. There is only 64bits PS driver for Windows 7. The another driver has nothing for W7.
      Only the fiery scanner is not easy, there are 4 possible drivers found. Which driver should better for D240 scan under W7 with built-in fiery controller (actually fiery controller behind D240).
