I've bumped into a real stumper, maybe someone has some experience with this?
I've attached an image. The band is just above the "rear of machine" notation. The uneven darkness at the bottom of the image is just my shadow... haha
I've got a LE->TE band, in cyan ONLY. It basically just intensifies any cyan in its path, if there is no cyan in that area, there is no band.
At first I thought it was something simple, but I've eliminated all the usual suspects, and now I'm at a loss.
So far, the following had NO effect:
- Replacing the drum
- Replacing the whole cyan developer unit
- Swapping the erase lamp with another color position
- Cleaning the CK ROS
- Cleaning the 1st BTR rollers in the belt assembly
What I haven't done, since it affects cyan only and no other colors, is mess with the fuser, 2nd BTR, belt cleaner or belt itself.
I also haven't swapped the CK laser unit from another machine, because I hate digging in to a good working machine (and my only backup at the moment) for the ROS units. Those flat foil cables SUCK.
Just in the process of typing this, one test I realized didn't do which I could pretty easily is swap the 1st BTR's inside the belt unit. I could swap the cyan and magenta to see if perhaps the 1st BTR is bad. I'll report back on that.
Does anyone else have any experience with a band like this?
Thanks!
Thanks!
