XEROX 4595 Uneven density
  • JRCS
    • 43
    Replaced IBT Belt - Adj and no difference - Copier has just over 2 mil - inboard is light. Any Ideas?
    JRCS
  • adriansto
    • 2387
    Re: XEROX 4595 Uneven density
    Uneved density after replaced IBT or you tried to fix uneven density by replacing IBT ?
    What is the partnumber of the drum modules inside you have the machine ?
    • JRCS
      • 43
      I replaced the IBT - was torn the copies were fine after - Customer ran about 150k then started to complain about it - the drum he is using (in the machine) 013R00646
      • Exok
        • Jun 2011
        • 750
        Force the machine to jam when paper just nearly under the drum. Pull out the drum unit and inspect the image on the drum. If the image on the drum has good density then you have a problem with transfer. If the image has poor density on the drum, you have a problem with either the drum or the developer.
        • fogra27
          • Mar 2011
          • 29
          first clean ROS then check metering blade in developer housing.
          Cau...
          • JRCS
            • 43
            Cleaned ROS then Adj. trim bar, is better, but looks like the problem is still there, much better but.... Customer ok with it.
            Thank you!
            • fogra27
              • Mar 2011
              • 29
              you're welcome
