Xerox 7125 - Error code 062-397
  • nvalen
    [Error Code] Xerox 7125 - Error code 062-397
    Hi All,
    I've got IISS fault (Error code 062-397) on Xerox 7125.
    What does it mean and what can I do with this problem?
    I guess it's something about machine's scanner - no copy, fax and scan, but printing is working properly.
    Thank you.
  • adriansto
    • 2387
    Re: Xerox 7125 - Error code 062-397
    Check CCD flat cable and coax. cable between IIT and ESS.
    If everything is ok then try to reload software.
    • SavyTech
      • Aug 2011
      • 15
      You can try replace this part if fault remains.
      Trans PWB part list 1.6 item 13
