any info would be greatly appreciated on this fault code :0 Thanks
xerox 4112 error code 012-909....seems to be a finisher fault..HELP
Re: xerox 4112 error code 012-909....seems to be a finisher fault..HELP
012-909 , Punch Out sensor static jam. (PL 17.117) Test the sensor in service mode input checks 012-105.
If no paper is present at this sensor, possible to be caused by sensor wires being crimped on to connector too tight breaking the wire at the connector and also tie wraps are too tight causing breaking of wires.Comment
