how can i change the regional code of machine WC7120?
  • seximibabay07
    • Mar 2013
    • 59
    hi! i heve 2 machines WC7120 and want change the regional code to acept any consumable from anywere or to DMO again...
    i need help, the machine are STOPED
  • landspeeder
    • Feb 2010
    • 355
    Have to call xerox 2nd level support
    You never realize how cheap a professional is until after you let an amateur do it.... and
    if this was an easy thing to do then everybody would be doing it! But it isn't and they are not!!
    • seximibabay07
      • Mar 2013
      • 59
      Re: how can i change the regional code of machine WC7120?
      the Xerox support give to me a Code to Change regional on WC7535, but a need Change another Machine Wc7120... I know needed real Experience to do it... our costumes Add a consumable from another regional Code, and so that we must to Change it to DMO again becouse our cinsumable came from south african region.... HELP ME!!!!!
      • JustManuals
        • Jan 2006
        • 9838
        Instead of 'help me help me' What about a PLEASE or a THANK YOU IN ADVANCE?
        • seximibabay07
          • Mar 2013
          • 59
          on last weekend, i changed the consumable code region to DMO again, the machine was WC7535...
          THE XEROX SUPPORT asked me the part number of consumable and
          with part numbers: 006R01517 , 006R01518 ,006R01519 ,006R01520
          Machine Serial Number: 3906179058
          Machine meter readings­: Total: 28044
          NVM values for locations:
          740-053 = 3
          740-055 = 2
          and they sended a code to activate de consumable region...
          Go to admin tools>Device Settings>Supplies>Supplies Activation Code, and enter code vby7ej
          now we have another machines WC7120 and the xerox support send to me another question too.
          We need the below information to request a snippet for the 7120:
          with part numbers: 13R00656,13R00657,13R00658,13R00659
          Machine Serial Number: 3321120660
          Machine meter readings­: Total: 124.363
