Xerox 4110 error 10-330
  • Imageer
    • Jun 2025
    We are stuck as to how to fix this error. Any help would be appreciated.
    The machine stopped in the middle of a run and gave a 10-330 error. The error then came on when we rebooted the machine after warm up. We looked it up and found out it was a fuser motor error so we replaced the fuser motor. Now the machine will boot and sit idle until we try to make a copy. The sheet comes to about an inch over the transfer belt and then the machine gives a 10-330 error again. What is going on?
  • Flash
    • 378
    Re: Xerox 4110 error 10-330
    Check the fuser bearings. They may be locked up.
    • Imageer
      Thanks for the reply.
      We checked that. Everything is moving freely. We also ran the fuser motor in service mode and it is working.
      • Flash
        • 378
        Check the pressure roller cleaning blade it may be digging into the pressure roller causing the fuser motor to stall.
        • adriansto
          • 2383
          Check also the fuser drive joint. There is a bearing. Also look at the fuser web material
          • Milo Wilson
            • 499
            It's usually the Pressure roll cleaning blade. It gets built up with toner and when the toner cools down it hardens and won't allow the pressure roll to turn
