xerox 550 vc konika c6000
  • tenatal
    • Aug 2011
    • 35
    which one is better ?
    xerox 550
    or
    konika minolta c6000
  • blackbooger
    • May 2012
    • 12
    Don't know much about the Konica but the 550 is a great machine
    • knightfall
      • Jul 2006
      • 633
      Re: xerox 550 vc konika c6000
      the Xerox 550 gives you control to replace the drums and fuser unit yourself the Konica C6000 requires a technician to do that which probably will take 3-5 hours to complete. Both can have a Fiery hook up.
      I work on both and I prefer the Xerox 550 over the Konica C6000 but ultimately you should go to both demos and get a feel for the equipment.
      Get your facts first, and then you can distort them as much as you please.
      • azehnali
        • Nov 2009
        • 679
        if you are in the toilet paper business Konica is the way to go
        • WIWA
          • Mar 2009
          • 97
          Well I have to tell you I got a customer with a Xerox DC 260( similar to 550) and recently purchase a konica c6000 wow a hell I can tell you well build and robust machine the fuser unit the rolls well build to handle heavy stock , 4 rips one for each color cool Ah! bypass well build either big robust feed rolls for heavy stock so at the I almost lost a good customer I'm waiting for c6000 to get older for problems to start up .
          Hope this Help,
          Wiwa 72 , Gonzalos Build, v.1.1
