ERROR CODE 042-326 in DOCU COLOR 5065
  • raj007
    Hi friends,
    I am a new in this thread, need some help from you.
    I am facing problem with docucolor 5065, every now and then it comes with EROOR CODE 042-326 and it said turn off and on machine, after i do that it works for a while and error come up again.
    I am new with this machine and i dont know anything about it, much appreciate if some one help me step by step to remove this error.
    Many thanks
    raj
  • WIWA
    • Mar 2009
    • 97
    Re: ERROR CODE 042-326 in DOCU COLOR 5065
    This code is related to your IBT belt unit maybe a dirty reflector on the IBT belt so the sensor can not track accurately the belt position and so the fault code so check it out.
    Hope this help,
    Wiwa 72, Gonzalos build v. 1.1
    • bojans
      • 1313
      First check your IBT if it's damaged. If everything is ok, you'll have to reset error code.
      If you dont know how to do it, at least you'll need SM.
      Best thing is to call service tech.
