corontron reset 7655
  • acsolutions
    • Jun 2010
    • 519
    [Misc] corontron reset 7655
    Hello, Working on a 7655 and the corontron indicator shows 5% left on unit. I am having a copy quality issue and need to replace it but I would like to also reset the counter. can someone direct me on how to do so! Thanks
  • Exok
    • Jun 2011
    • 750
    Re: corontron reset 7655
    To reset:
    Remove the black drum unit.
    At the rear just below the corotron you'll see 2 holes.
    Take a paperclip and bend it so that it fits in the space you see when you look in from the rear.
    Make sure the paperclip is blocking the area where the holes are.
    Reinstall the drum with corotron unit.
    Slide the drums back in and close the front door.
    Check the supply screen to make sure it now reads 100%.
    Now go back and remove the paperclip.
