xerox 5230 authentication
  • Jude
    • Oct 2009
    • 256
    Please tell me there is a way to reset authentication because customer reset default from 11111 PW: x-admin to who knows what? Is there a way to access web monitor to change smb settings?
  • livewire
    • Sep 2011
    • 608
    Re: xerox 5230 authentication
    Follow General Procedures (GP3) in EDOC.
    • Jude
      • Oct 2009
      • 256
      I have been a copier tech for 18 years and still I have no idea what that means. Please help with any documentation or procedure. I thank you in advance and look forward to your kind response, sir.
      • Exok
        • Jun 2011
        • 750
        GP3 = General procedures section 3
        EDOC = Electronic documentation (service manual)
        • Exok
          • Jun 2011
          • 750
          Resetting the Admin Password:
          Enter UI Diagnostic Mode. ( Press and hold the 0 key for 6 seconds then press START while still holding 0. Enter code 6789 and confirm)
          Press LOG IN/OUT button on control panel
          select SYSTEM SETTINGS
          select COMMON SETTINGS
          select DIAGNOSTICS
          select NVM READ/WRITE
          enter location 700-171 and press CONFIRM/CHANGE
          This is your current password. You can provide this number to your customer or set this NMV to the default value of 11111.
          • Jude
            • Oct 2009
            • 256
            select DIAGNOSTICS
            mucho thanks!!
