DC 2060 smudged print - repost
  • Ignis
    • Aug 2010
    • 28
    Hy, I have some nice problem, for me is hard but i believe for you is light one!
    when printing on any size of paper between 80-130 gr. uncoated weight paper I get this smudged print.
    On heavyweight coated 280-300 gr. matt paper print is fine.
    In meanwhile i changed new fuser heat roll, and complete fuser belt assembly. Only oiler assy is older
    why is this happening?
    Update: Problem is before fuser, already on vaccum transport. Then I think problem is in 2BTR roll in paper tray modul or 2BTR backup roll under IBT Belt.
    thanks
    Examples of print in attachment are printed on 120 gr. uncoated premium paper (A4 LEF) (Long Edge First)
  • azehnali
    • Nov 2009
    • 679
    Re: DC 2060 smudged print - repost
    take the gear that is about one inch in diameter out of the btr assembly
    • Ignis
      • Aug 2010
      • 28
      Gear that drives 2BTR in paper transport modul? so that there is no own transmission?
      • Ignis
        • Aug 2010
        • 28
        Thanks, it works! solved
        • duanew
          • Mar 2012
          • 35
          From Now on you have to remove the gear evertime you replace the 2nd btr
          intill you fix the locking transport gear in the back that is crack
          this is how lazy xerox tech's fix this problem
          have fun that gear is a serious pain to replace
