Xerox 5000 - how to change hemisphere
+ More Options
Posts
  • vibin
    • Sep 2011
    • 38
    HI all,
    Please tell me how i can change the hemisphere for the Xerox 5000 as i want to get toners from USA as well as UK for my 5000.
    Kindly assist on this.
    Thanks & regards
    Vibin
  • Exok
    • Jun 2011
    • 750
    Re: Xerox 5000 - how to change hemisphere
    Priceline.com | Best deal on Hotels, Flights, Cars, Vacations & more!
    • davidj7
      • 1107
      just change the drum and toner chips from the one you are replacing to the new cru/eru and your machine will run fine . I dont see any point in chancing the Xe/xc nvm's since you are getting toner from both the regions
      a machine is only as good as your tech : source:screwtape ; the scary one
      • vibin
        • Sep 2011
        • 38
        Thanks for this...but at times in get in 20 sets when i get a good deal so it becomes difficult to change it and am lookin at geting from the uk since the transport costs are better for me...i will need to keep changing the chip...so if i can change the NVM it would save me time.
        • vibin
          • Sep 2011
          • 38
          Hi,
          now am getting toner from Uk Only. Pls let me know how to chnage the hemisphere.
          Vibin
          • Milo Wilson
            • 503
            You have to reload the dell PC box and make sure during the load process you tell it European market.
            • ktxerox
              • Mar 2009
              • 229
              Yes there few NVM which required to change the region. i remember i done it 4 years back let me check if found the this email.
              • ktxerox
                • Mar 2009
                • 229
                Also check the NVM list in right hand cover. there ship location information must be entered.
                • vibin
                  • Sep 2011
                  • 38
                  Thanks for this.
                  Changed the NVM's and now shows the readings perfectly.
                  Vibin
