Xerox 5675- system unavaillable- communication error
  • gregoriojc
    • Aug 2008
    • 56
    [Error Code] Xerox 5675- system unavaillable- communication error
    Any one can help me pls. the xerox 5675 when put on the display is showing''system anavaillable. do not power down untill message appears'
    and then after a while is showing " communication error"
    please need help
    gregoriojc
  • Guest
    Re: Xerox 5675- system unavaillable- communication error
    Resetting the device has
    The default
    That part does not make an error check now
    Cable connection or replace it
    Czech flat cable
    • gregoriojc
      • Aug 2008
      • 56
      The default
      Czech flat cable
      Ok thank you very much, I will check the cables and wiring
      • CaptnRed
        • Apr 2011
        • 57
        I'm having the exact same issue! Were you able to resolve this Communication error?
