Hi can anyone please help with the error 006-372 error on the Xerox DCC450 I'm getting its the ROS motor fail. Any idea what that is or located?
Xerox DCC450 error 006-372
Re: Xerox DCC450 error 006-372
The ROS motor is the polygon mirror motor located in the laser (ROS) unit.
You can check to make sure that the wire harness going to the laser unit(s) are properly connected but beyond that you would need to replace the ROS assembly. -
Hi,
thank you so much for your help. I ended up removing the ROS Motor and cleaning it and worked fine. The motor was jamming up a little trying to rotate.Comment
