Xerox 5330/7545 116-324 codes
  • Flash
    • 378
    Has anybody had problems with 116-324 codes on the 5330s or 7545 series machines? I have several machines at different locations at the same company giving this fault code. I think it may be something on the network causing it or an application they are printing from.
  • Exok
    • Jun 2011
    • 750
    Re: Xerox 5330/7545 116-324 codes
    I would have to agree with you that it is probably something on their network causing the problem.
    If it was just 1 machine out of all the machines at the account having this problem, I would suspect the printer but since several different machine are all having the same problem it does not seem likely that they all have hardware or software malfunctions.
    • adriansto
      • 2387
      Same IP address on many machines.
      That is the reason for DHCP was invented.
      • max2013
        • Mar 2013
        • 54
        i have some of this problem also mike try to reload the printer driver is this happen while using printer copy and other function no problem ...
        • giaco
          116-324 is an IE font glitch or incompatibility issue with fonts that the xerox doesn't understand, especially if printing from within IE (internet explorer). in your printer driver go preferences, advanced, specify font, setup, tick "print true type as bitmap" and apply changes . otherwise print file again using firefox or chrome
          • Nzer
            • Sep 2014
            • 34
            If still having problems after following this and the cust cant or wont use another browser, using the postscript driver can be an option if the machines have postscript installed
