Work Center 5687 Defaults
+ More Options
Posts
  • echidnadsn
    I have two Xerox Work Center 5687 and they are both apparently set to different default settings, although they never used to be.
    The desired effect that we want is for all Copy jobs to go to the top tray and all Print jobs to go to the Stacker tray. Up until a couple months ago they both did this, however it seems as though a setting was changed on one of them at some point and is sending all Copy and Print jobs to the Stacker tray.
    I have gone through the settings, however i don't see anything that allows me to change my destination, either in normal copy settings or in admin settings.
    Any idea where i would find this setting and how to change it to revert to the desired outcome?
  • Exok
    • Jun 2011
    • 750
    Re: Work Center 5687 Defaults
    You can find many helpful tips at Xerox Document Management, Digital Printing Equipment, Business Process Outsourcing
    Select the Support and Drivers tab, enter your model number then select support.
    Solutions for : How To Modify the Default Output Tray for Stapled, Non-stapled, Punched, or Non-punched Paper (Copy, Fax, Print Jobs)
    Solution : Modify the Default Output Tray for Stapled, Non-stapled, Punched, or Non-punched Paper (Copy, Fax, Print Jobs)
    1. Access the Tools menu on the Touch Screen. See the Related Items below for additional information.
    2. Select the [System Settings] tab.
    3. Select the [More] button twice.
    4. Select the [Output Options] button. The Output Options screen will be displayed.
    5. Select the [Output Location] button. The Output Location screen will be displayed.
    6. Select a paper output type button. The options are:
      • Non-Stapled and Non-Punched Jobs
      • Punched and Stapled Jobs
      • Stapled Jobs
      • Punched Jobs
    7. Select the required job type button: [Copy Jobs], [Print Jobs], [Fax Jobs], or [Reports].
    8. Select the required Select Tray button: [Output Device Top Tray] or [2000 Sheet Finisher Stacker Tray].
      NOTE: The exact tray options presented will depend on the type of Finisher installed.
    9. Select the [Save] button.
    10. Select the [Exit Tools] button.
