DC12 firmware upgrade
  • Enzo
    • Jul 2009
    • 407
    [Misc] DC12 firmware upgrade
    Hello friends. I have 2 xerox DC12 and I have a problem with the collated copies. Basically my problem is this:
    my machine has the finisher and the ADF.
    Example: I send to the printer from the computer 10 sheets to make 3 copies. All 3 Copies are collated.
    The same sheets if I send them to the printer using the ADF, copies do not come collated.
    How can I fix the problem? On the display there is no the "collate". It is a software problem? I have the version 11.50.3.-1
    There is a need to upgrade the hardware? How is it done? thank you very much
  • Enzo
    • Jul 2009
    • 407
    Re: DC12 firmware upgrade
    Nobody helps me?
    • Enzo
      • Jul 2009
      • 407
      you need the diagnostic program or need anything else?
      • xcopytech
        • Aug 2006
        • 1792
        Dc12 can not make collated copies.
        • Enzo
          • Jul 2009
          • 407
          hello friend. thanks for the reply. I am sure that it collates copies as I have seen in other machines (always dc12) who had command on the display that I do not appear.
          My request is simply to know how you upgrade on that machine.
          • Enzo
            • Jul 2009
            • 407
            Hello friends. No one can help me to make the upgrade firmware for this machine? I have the pws and diagnostics. Thank you
            • subaro
              • Oct 2010
              • 1274
              don't know about this machine. but in order to collate, you first have to select the number of copies and then the collate function will be avaliable to be selected. This you may know, but sometime the simple steps are missed.
              • Enzo
                • Jul 2009
                • 407
                Thanks for your reply but I want to know how to update firmware to solve other problems
                • xcopytech
                  • Aug 2006
                  • 1792
                  Do you have firmware for dc12?
                  You need PC with XP or older OS because WIN7 do not support parallel port.
                  Copy firmware to root (c,d or even on usb but must be on root).
                  Start download and download firmware
                  • Enzo
                    • Jul 2009
                    • 407
                    I have a PC running with xp. I use perfectly the pws but unfortunately I miss the firmware file!
                    • Enzo
                      • Jul 2009
                      • 407
                      anyone can send me the firmware file?
                      • Milo Wilson
                        • 499
                        I have what you need. Do you have anything to trade for it?
